Here is an install I just did with many many thanks to posts from EOC!
I did the Valor RM-921C. I got it on Amazon for $308. Crutchfield has it for $449. The instructions were a C- at best. The damn manual had typos and it looked to be a rough translation from jibberish to english. Again, many thanks to posts on EOC that got me through. I did it first time with no hang ups. Just remember, the GREEN AND RED wire is all you need to connect your dome light hook up to (and a ground). If your dvd monitor has a polarity switch - the ELEMENT IS NEGATIVE!!!!
I used add-a-circuits to pick up power from the hazard lights in the engine compartment fuse box. To get my wires to the fuse box (through the firewall) I used advice from this post. Although I did not do it exactly like that. I just stuck my wire through the grommet, then I opened the driiver's door and fished up the wire with a coat hanger. From there I fed it to the engine compartment via the open fender well. Everything fits snug! The grommet was then smeared with marine adhesive to prevent water coming in.
I inserted a 8 x 10 inch piece of luan board over the factory domelight hole in the headliner. I then bolted that to the two factory holes where the domelight was connected. In the pics you dont see the washers I later used. I also later cut out the middle of the board to feed the wires. That was about the worst of it. The rest is all basic. This monitor has a dvd player built in with FM modulation which works pretty good - better than I thought. I may later run an audio feed to the radio, but right now it's good enough for the kids. If I want to watch I movie Ill just use the wireless headphones.
