1 - 17 of 17 Posts
I'm new the EOC world as I recently purchased a 2006 EX a few weeks ago and am having a great time owning an Element. One of the first things I did on EOC was research all the different types of floor mats. Out of everything, I came to conclusion that either 1: they didn't serve the purchase I was looking for or 2: they were too expensive. So I decided to give a it a shot and make my own.
I chose to go with an Anti-Fatigue Foam Mat from Home Depot. Main reason: thickness/density of foam. I knew that lining the car would reduce road noise. Now that I have it in the car, I can tell you it made a HUGE difference in road noise. Exceeded my expectations and in my opinion, came out looking pretty good too.
Cost per mat: $20
Dimension of each mat: 3'x4' and .25" thick
Purchased 3 mats - Total Cost: $60 plus a few hours of labor
Hopefully the pictures will explain the process I took.
Black White Floor Font Architecture
Font Design Wood Pattern Rectangle
Floor Font Mat Pattern
Floor Mat Flooring Auto part Metal
Floor Tire Carbon Automotive exterior Synthetic rubber
Floor Flooring Metal Tile Steel
Floor Auto part Mat Flooring
Vehicle Red Car Vehicle door Automotive exterior
Automotive exterior Bumper Vehicle Car Auto part
I used scissors to cut the mats out. A razor blade didn't look near as good.
Hopefully this helps someone else out on making a decision about floor mats, maybe not this idea, but a smarter choice on something.
Thanks, we shall see how it holds up in the long run. Nice part about it is if it does wear down, I can just replace that section for $20.
Approved. Nice job. I love seeing people solve problems effectively.
I have similar mats from Pep Boys lining the back of my garage, and they have held up great. The only damage they've sustained is from welding, so there's some pinhole burns.
Did you use anything on the backside to hold them in place?
Mcdirtymetal: That's good to hear on the quality of the mats. Also, I didn't use anything on the underside. They are very "grippy" and hold in place extremely well on their own.
very cool mod.
I like the function and look!
I'll def do this mod if I ever get tired of my home depot carpet, especially now that I have a dog.
thanks for sharing the how to photos.
I followed this today to make a front mat. It took about 1.5 hours to make the pattern and cut the mat with sharp shears.
It fits nicely and doesn't slip. And looks great.
Thanks for posting this -- and for posting the detailed photos!
GreyDawg
Discussion Starter · #13 ·
That's awesome. This was my first Post/Thread on here and it feels great I could share what I did. Hope your front mat works out as well as mine have for me.
BLB
Just picked one of these mats up at HD...$20, bout an hour of measuring and cutting, and a new front floor is there- can't wait to drive it around and maybe hear a noise difference. Will do the rest of the car soon...I left the area near the clutch complete- made two cuts but not 3, near the "dead pedal" section- looks good and I'm happy with it. No movement at all! Also going to take the leftover stuff and put it on the tailgate as that can get slammed when I'm putting big ol stuff in (usually large rocks/logs/garden things) Thanks for the tip.
2004 EX AWD
I'm just going to bump this thread as I just did the same thing. I will note, many HomeDepots sell a 4'x6' version of this mat for $40. It is large enough to cover the whole rear cargo area behind the front seats in one piece. It is about an inch short at the very front, but that area is covered by the front seats. I thought I came up with this idea myself, but a search found this thread and I can't believe more people haven't done it. The slippery floor has been driving me crazy. The noise reduction is an added benefit. There is a very slight odor, but not bad at all. I expect it will dissipate quickly. Nothing like Harbor Freight when they get a shipment of tires in!
I used a 3'x4' mat for the front, but did it on two pieces. I haven't decided yet how I will address the cutouts for the rear seats. I think I am going to make cutouts but leave the pieces in place since I rarely have the rear seats down. Or maybe flaps. I don't want the two big holes in the otherwise flat floor.
2007 ELEMENT SC St¡ck
wow! it's a great job! is it rubber this mat?
how did you cut it?
honestly I'd buy the whole piece from the rear- between the seats row and trunk area. if it's possible to make one big piece!
cause I didn't understand your masking process - like you take little pieces of paper cut them by the shape and stick with each other?
make a video or if you could make me a rear may - I'd buy!
you can start a business- rear big piece is always in high demand!
please message me here!
great job!!!
2004 EX AWD
yes, the mat is rubber, a little less than 1/2" thick. You can use the larger 4'x6' mat to do the back in one piece. It cuts easily with scissors or a razor blade.
I can't speak for the OP, but when I made the template for the front, I just used plain printer paper and taped it together with masking/painters tape. I also cut some areas to match the contours. For the back, I didn't make a template. I sort of wish I did since making the template was pretty easy and it comes out better. Very happy with the results and the price. An entire floor kit for about $70 and an hour or two of time.
1 - 17 of 17 Posts
