2004 Honda Element EX
I have a 2004 EX with a fog light bulb that’s not working. I like to replace the bulb but not sure how to go about it. I noticed someone posted a link on an old post but the link is no longer valid. I have searched this forum but could only find limited information. I can see that there are two screws behind the fog light. Which screw is the one that will loosen it so I can replace the bulb? See attached pic. Any information is greatly appreciated. Thanks!
2007 Element EX TRP
No, you do not have to come through the back (you can, of course, but more laying on the back work), just remove the foglight housing from the from the front (phillips screws), then take the housing apart (again, phillips screws), change the bulb(s). 15 minutes, give or take. :cool:
Discussion Starter #5
Sorry for the late reply. I managed to get the fog light out and replaced the bulb. I wanted to replace the other one, but found the screw was stripped. I plan on replacing the front bumper as it has some damage but not ready just yet.
Thank you for the advice and replies.
