If you have the $240 to spend, I say go for it. Congrats and it's a good mod. It's a mod worth having. We use our driving lights all the time. I always change the factory bulbs to hyperwhites with higher wattage. It's a huge difference from stock bulbs.
I like that very slight hint of blue and more white. I do not like it when its got too much blue.
I removed the bumper cover to install the walmart driving lights in order to do a very clean install and to make sure that the wires are zip tied nicely and not rubbing against any metal. Wire chaffing is one of the most common causes of electrical fires/shorts in vehicles from after market electronic installs/upgrades.
If I coud spare the $240 for driving lights, I would have bought the Honda OEM and still replaced the H3 bulbs with the hyperwhite h3 bulbs.
The only honda part I used is the switch. It gave a clean, stock look to it. The Walmart Fogs does the job, specially after I had replaced the bulbs. It does stick out a little bit but doesn't look bad at all.
The fog light bracket mounted to the bumper cover.
The OEM fog light switch and custom wiring harness.
BTW, post some pics of your newly installed Fog lights with the lights off and on.
John
