1 - 10 of 10 Posts
Hi hope everyone is doing well in these times.
I have a 2006 LX that I've decided to try to replace the front motor mount myself (as suggested by PPI).
Looks easy enough, just jack the engine up, take out 3 flange bolts, and replace mount.
My question is: should I/would you recommend also replacing the 3 flange bolts + nut holding the motor mount, just to be safe?
Thanks.
/repost from reddit r/HondaElement
2007 Element EX TRP
Unless you find corrosion/rust/undue stress on the bolts, I would second seagiants' suggestion - just re-use them. AFAIK they are not a one time use nut/bolt combo, so reusing them should not be an issue. Good luck!! :cool:
Discussion Starter #5
Got it thanks. So as long as I just see some surface rust on the bolt head, but no rust/corrosion on the bolt thread/length itself, it should be OK to re-use?
Hi, did you use OEM parts or aftermarket? I am also having trouble finding "motor mounts" in part sellers websites?
Hi,
Your waaaay over thinking this!
If the bolts have a little rust, clean them, oil them, and use them.
No problem!
2007 Element EX TRP
Yep, should be fine! Clean up any rust and maybe some rust protectant paint after installation, then drive on!! :cool:
1 - 10 of 10 Posts
