121 - 133 of 133 Posts
Shrinkage solution?
Maybe a couple of those little silicone stick-on door bumpers set in the window frame would be just enough to hold the reflictix in place as they loosen up
I realize Reflectex is opaque, but gosh, that gives me an idea: ordinary small-cell bubble wrap should provide privacy because it's translucent, yet by the same token would keep the car from being a dark cave; plus it should insulate reasonably well. You could trim it into window-size sheets, held in place with Velcro at the corners. Hmmmm.
12 years later and this is my favorite thing I've seen on the EOC so far. Got a roll in the garage. Might even insulate a bit too (but probably not)
This is the first thing I'm going to do for camping! Is there a template floating around somewhere? If there isn't, there should be one! If i end up making one that's share worthy, I'll make sure to upload it, but if someone out there has been nice enough to upload one, I'd be very grateful!
read over all these. Some really great suggestions. Looks like I will be using a couple of the ideas. I won't be going all reflectix all around. In fact, I think I will just get some car shields from the dollar store to do some of the windows instead. I plan to go to the fabric store to cover them black instead of spray paint as well. Will upload pix when I am done. Thanks guys and gals for all the great ideas!!
*sigh* well the things that used to be available at dollar tree apparently no longer are. Went to 2 different ones. Will try again tomorrow to see if I can come up with a good and economical solution.
2007 EX
Maybe Walmart?
Or I found these on Amazon:
Sunshield 1
Sunshield 2
Sunshield 3
It really might be easiest to go to a hardware store and buy some reflectix. You can calculate how much you'll need and have them cut you a strip from their giant bulk roll.
Also, there are some YouTube videos around this topic that may be worth checking out.
I bought two of the smaller pre packaged rolls and it is _exactly_ enough to do all the windows.
Okay, so I went to a local $0.98 store and picked up a sunshade. The height is just about right for the sunroof and I had to do some minor trimming. I taped up the edges with black gaffer's tape and installed some grommets and suction cups. The whole process took about 20 minutes and the fit is great!
I did all the back windows with cardboard that I got from work. Just cut to shape and pushed under the paneling. Did the front windows with black plastic bags, and the windshield with a generic windshield cover on clearance at walmart. Lived in my E for 4 months in my work parking lot until my transfer went through. All in winter. Benefit to the cardboard is its bettit's better insulation. I finally moved in November last year and was still sleeping in my underwear because I was rosting.
