the rubber lining between the upper front-side panel and lower front-side panel started to come off with a small loop...... i have attached the photos to describe the situation....
1. what caused it????
2. with the rubber loose will it accumulate water?
3. should i be concerned of any rusting (inside or with the lower half of the upper front panel)? I know the lower front panel is plastic but the upper portion is metal
4. is this an urgent fix?
5. how should i fix it???
