For sale is the following items:
1.) Custom element roof rack welded together with Thule fairing. Had the rack welded together, spans much farther than Yakima load warrior basket. Hard mounts to the top of the car using the 6mm hex bolts. Cost $350 to make and another $80 for the fairing. Currently, fairing is zip tied to the rack, never got around to attaching it some other way. Would be easy though. The rack was sprayed with bed liner that has since faded and chipped off and peeled in other spots. Needs to be sanded down and either sprayed with something else or powdercoated. Asking $150 for the rack and fairing. No shipping, local pick up only. Don't have the time to ship.
2.) Element lift- Its the "sparman" lift using lift blocks and all the camber adjustments. Will post pics when the lift comes off Friday. Basically the lift is great, uses lift blocks from a 4runner and F250. That along with the welded lengthened bolts to the top hats. What its included is the 4 blocks, front camber bolts, rear SPC camber arms, top plates for all 4 shocks with welded bolts and all other necessary hardware. $250 and will ship.
Pics of the rack and lift.
