Greetings,
I just purchased a new 09 EX 4wd. I really like it so far. I have an odd issue. The gas cap cover is sunk in. In other words the little hole where you put your finger to pull it out is sunk in so you can't access it. At first I thought an adjustment to the cover would handle it, but the dealer ordered a new one. I've been looking around at other elements and my conclusion is the plastic body panel is buckled or not fastened down all the way. When I push it it the cover is perfectly flush. Anyone else seen this? If so what was your fix?
Thanks for your time to read and response - Russ
