1 - 1 of 1 Posts
I found that a floor tile spacer, (the plastic piece used to separate and properly align the spacing in between floor tiles during installation) to be the perfect shim to fix the gauge cluster plug problem
If fits in perfectly under the wider of the two green plugs behind the gauge cluster and has a tab to easily pull it back out if you need to remove it when taking the cluster out to change bulbs
Just be sure to install this tile spacer/shim on the underside of the plug. It has worked perfectly for me and the lights never flicker anymore. Before that I had the usual symptoms everybody else has. Lights would sometimes go on and off over bumps, sometimes hitting the top of the dash would fix it for awhile etc
209741
209742
209743
1 - 1 of 1 Posts
