1 - 2 of 2 Posts
I have an 07 EX AWD approx. 160K- I've had it for several years and its my second E after the first '03 was taken out by a driver who neglected to read road signs.
I have a growl that seems to come from the lower passenger side but its hard to tell.
Only happens when moving- I can never get it to happen when stationary or by rubber using a rubber mallet on anything underside.
Often happens when coasting but its not limited to such, can also be triggered or amplified by going over a bump
Happens when hot or cold - after a long drive or 2 mins after pulling out of the garage
Moving into neutral does not stop or affect it
Happens when in or out of gear - does not seem to be speed related as It can 'flare up' into a growl after slowing down at a intersection or after turning into a road.
At first I thought it was being caused by plastic panels and trim vibrating in the wind, but I've secured everything - put it happened without a lot of speed or wind.
Has been occurring on and off for about 9 months now.
I recently had new rear brakes, rotors, lower control arms, ball joints, sway bar and tires but this did not change or fix the issue.
Any thoughts?
2007 Element EX AWD AT (two!)
Get it up on jack stands, start it, put it in gear, then be very careful around the moving tires/wheels and listen for the sound. Probably a good idea to have a helper inside the car to stomp on the brake or shut it down in a hurry if necessary. Use a paper towel tube as a stethoscope to help isolate the source of a noise. With the engine idling, you should be able to use a piece of wood or something against each tire to slow it down/stop it one at a time to see if the noise stops when the wheel stops; the other wheels should continue to spin.
PS: When did Texas join Canada? Under your username, it displays the Canadian flag.
1 - 2 of 2 Posts
