Take off front bumper. Remove old headlight, swap over bumper support attached to headlight, install new headlight. Put front bumper on and you're done. Should be all there is to it.
How's the replacement so far? I was helping my buddy installing the brake kit and lexani rims on his truck when his brother came on his 2008 Element with scratches on the passenger side bumper and headlight after hitting a tree. Saw this old thread, could be helpful if the photos are loading: Headlight Replace Guide - w/picturesSo I just got some OEM headlight assembly's for my 2010 Honda Element. The current ones are rock chipped and hazed up. How hard is it to swap the new ones in? Anyone done this or have a guide?
Thanks.
Did you ever get an answer about this? I’m trying to replace mine and curious how and if I need to remove the bumper. Thanks!I know with the original Elements you have to remove the front bumper, but with the 2010 model are you sure I have to get the bumper off? You see how with this model it looks like I have pretty good access to the lights without having to remove the bumper.
But if you're sure I need to, do you have a guide for removing it?
