I had the Silverstar bulbs in which one crapped out after a short period of time. I put the stock bulbs back in and was fine with them but just yesterday the drivers side burnt out. Not a problem, I have done this before and now I know how to do this - pretty easy once you do it once. Anyway, bought a new pair so I could replace both.
Drivers side went in one, two, three. I said ok, let me do the passenger side as well before it gets dark out. Pulled out old, stuck in new, turned to put the rubber piece back on and before I knew it, the bulb fell in. I know you are going to ask how can this fall in, but it slipped in. I mean it is not like it fell all the way down, it is just in beyond the normal spot and will not come out.
I have tried every which was I could, turning and turning, jiggling and such, but the bulb just will not come out. I have tried to line up the tabs any which way possible and still the bulb just will not come out!!! :evil: I even put the plug back on and tried turning and such - no dice.
Has this happened to anyone else???? Any ideas on how to get the bulb out??? Right now I have it plugged in just in case I do have to drive somewhere, but I cannot keep it like this.
