2005 Element Heater Control Assembly from Honda $225. Lots of them in salvage yards $25 - $50 at car-part.com. Tell me how much time to trace the controls to the motors especially if you don't have the tools. You can specify your area of USA. Mode motor assembly 79140-S9A-A01 $56 from Honda fits 02 - 06 CRV, 03 -09 Element. Mode motor in behind glove box. Probably get that thrown in with the control assembly. Sounds like it is the mode motor. Might get that for $10 from salvage yard. Not often either of these items crap out so chances are good that a salvage part will be OK.
Air Door Actuator / Motor:
Testing and Inspection Mode Control Motor
Mode Control Motor Test
1. Disconnect the 7P connector from the mode control motor. NOTE: Incorrectly applying power and ground to the mode control motor will damage it. Follow the instructions carefully.
2. Connect battery power to the No.1 terminal of the mode control motor, and ground the No.2 terminal; the mode control motor should run smoothly, and stop at Vent. If it doesn't, reverse the connections; the mode control motor should run smoothly, and stop at Defrost. When the mode control motor stops running, disconnect battery power immediately.
3. If the mode control motor did not run in step 2, remove it, then check the mode control linkage and doors for smooth movement.
- If the linkage and doors move smoothly, replace the mode control motor.
- If the linkage or doors stick or bind, repair them as needed.
- If the mode control motor runs smoothly, go to step 4.
4. Use a digital multimeter with an output of 1 mA or less at the 20 kOhm range. With the mode control motor running as in step 2, check for continuity between the No.3, 4, 5, 6 terminals and the No.7 terminal individually. There should be continuity for a moment at each terminal as the motor moves past the switch's terminal.
5. If there is no continuity for a moment at each terminal, replace the mode control motor.
