I am so torn between switching out my 16'' stock rim with either 16's or 18's.
The big plus for using the 16's is I get to use my current tires and save a ton of money. I am just worried that they will look goofy being so small. 18's will look much cooler.
on the other hand, I use the E for long road trips and need it to be tip top grip in the snow. would the 16's be the wise choice in that case??
will they give me better grip in the snow, smoother ride and better mpg?
please assure me the 16's will look cool. that is my only hesitation
here are the rims i want :grin:
MSW Type 20(Machined w/Black Accent)
Offset: 45mm
Backspacing: 5.74"
Bolt Pattern: 5-114
Rec. Tire Size: 215/70-16
Weight: 19.2lbs.
Finish: Machined w/Black Accent
can someone please photoshop the rims on my car. PLEASE
Offset: 45mm
Backspacing: 5.74"
Bolt Pattern: 5-114
Weight: 19.2lbs.
