2003 Element EX 2WD side airbags.
Gauge cluster backlights, HVAC lights, AT shifter light, cruise main light, emergency flasher light are out and not working.
So UHFB Fuse 2 and UDFB fuse 10 are good. G502 is also good.
Backprobing instrument cluster gauge pins A14 and A11 show good solid power, and A15 and A30 good ground.
A16 when backprobed has inconsistent ground signal and measures 1V on the meter. When connector A is unplugged, it’s got solid battery power on the red A16 wire.
Id like to make the call of a bad gauge cluster, but I’m not sure what the voltage regulator, capacitor, and variable transistor are doing to my measurements at A16.
If you guys have any idea what I’m talking about, I’ll appreciate any help.
