Hello...
I have used the search function, and learned a lot...like how to get through the firewall, and many other things.
My question is this. I need to ground 1 wire from the on/off switch, and 1 wire from each light. Would it work ok for me to ground them under the hood, where the negative battery terminal cable grounds (there is a nut with a green dot on it to the right of the battery on the frame, where a wire runs from the it to the negative cable)?
