The only way to fix the squirrel finder is to block the holes on the cutoff shield.Weird, I have a 5000k HID with a 35w slim metal ballast and its pretty bright. Of course not as bright as the OEM HID setups which I think is the best.
I used to have a OEM HID ballast, OEM 4300k d4s bulbs, etc. out of a Prius on my non HID RX8 and it was literally like daylight, great dark blue cutoff line, only problem was the squirrel finder light that shot straight into the front cars back mirror, pissed alot of folks who needed anger management...
Anyways, the peep hole aka squirrel finder, light, you can see it up against the wall its right above the cutoff line, directly in front, the closer you are to the wall the lower and more intense. I know we all have it, unless you retrofitted a real HID projector.
I guess I gotta gut the headlights...
The only way to do that is to open up the headlamps and then open up the projectors to block off the holes (squirrel finder) on the shields, so you can get rid of it.
Here's a link to block the squirrel finder:http://www.hidplanet.com/forums/showthread.php?13534-How-to-Fix-Squirrel-Finders
