I've had it off for the last 6 months or so. The only issue I ran into was that my exhaust melted the 2 delrin washers that sit above and below the swing arm. After I realized what happened, I ended up removing the whole assembly and got my exhaust rerouted to the side. Next up is to get a new set of washers and clean up a little bit of rust that I believe was caused by the melted-washer-turned-goop-blob trapping water against the swing arm's lower knuckle.
I still like it and it's definitely going back on, just have had more important things pop up (e.g. work, new motorcycle). Once I get the washers in and/or have a longer distance trip planned, I'll put the work in to get it back together and on the E.
