I just purchased a 2003 EX. When we start it the horn honks once. Any ideas? We only ave one key and no remotes either.
agreed. it is either that or someone that was playing a joke on the previous owner. we have hooked many things to people horns in the shop over the years from brake pedal/lights to headlights to reverse lamps, etc. the way to tell if that is the case is does it honk the whole time you are cranking the starter or is it just a short burst of the horn? if it does it the whole time you crank then someone was playing a joke and you just need to get in there and clip the horn loose from the starter wire. if it does it after the crank is complete or at some differnt time then you have an alarm that you probably want to take out if you dont have the remotes. i would say that you could get remotes for it and have them programmed but i dont know what type it is that would do that with the horn at start up, and it is def not a dei product that i could walk you thru remote programming.Sounds like an after market alarm
