1 - 20 of 27 Posts
VIN decoder
Use a VIN decoder. www.decodethis.com Yhis will give you all year make model engine drivetrain information for all cars
Just check the roof. All the 4wd E's have a sunroof. Of course that is only valid for 2008 or older. 2009's don't have sunroofs.
do you mean the sun roof over the two back passenger seats?
Another way is to look under the back of the car and see if there are half-shafts from the wheel to the center of the car.
se
I keep seeing this question pop up again and again here. My '08 has a blurb for all wheel drive painted on the rear glass (which I assume can be removed) but how many models was this done for?
I think the RT4WD sticker on the back started in 04 because my 03 didn't have one.
The decal for 4-wheel drive started in '05.
The easiest way to tell if your E is four-wheel drive is to look for the sunroof... if you have one, then your E is four-wheel drive...if not, then it's front-wheel drive.
Wait so when you say sunroof, you mean one that you have a switch to control or are you talking about the one that is in the far back?
If you have a sunroof with a switch to control it, inquiring minds would like to know where you got it...
1 - 20 of 27 Posts
