1 - 19 of 19 Posts
My element will not go out of park. I understand it may be the stop light switch. How do you install a new stop light switch. I know it is on the break peddle. It seems just to clip in.
Any other ideas regarding how to fix this problem.
thanks
1st....check if the brake lights work. ;-)
if they do, it ain't the switch.
if they don't, check the fuse! (can't remember the number...there is one under the hood and also the fuse panel at the dash...I think.)
Here is a link w/ some info on the "PARK interlock"
Here is a link w/ some switch info....look around at posts #14 and #22 or so.
Good luck.
Will
Discussion Starter #6 (Edited)
Brake light Switch
Thanks for the information Will. My brake lights work but still replaced the switch. After I replaced the switch, I got it out of park several times. I thought things were good so I put the fuse panel back on and then it locked again. Brake lights are working. I adjusted the switch closer, further away, etc. It didn't help. I thought it might be a loose wire but didn't know how to test that except for moving them around. The TPS thing on the trottle is beyond my skill. I may go to Auto Zone to see if I can pin point things with an error code.
Will keep you posted.
Thanks again.
Cheryl
someone a few ago had the same problem,,it was the selonoid inside the shifter..if you search around you might find that tread..good luck
Info about the selonoid & shifter are in that first link about the "ParkInterlock" I posted.
Discussion Starter #10
Stuck in Park!
I fixed it, yeah! It wasn't the brake light switch though I learned how to change it so I have a new one. It was the #10 fuse. It amazes me that it was that simple. Thanks again to all who tried to help. I learned a lot.
Cheryl
This reminds me that I've been wanting to switch all of my fuses to that new "lights up when it blows" kind.
I tried some of those Fuses that light up in 2005. They worked, and never had one blow. So I can not say that it worked as advertised. This was what enticed me into trying them at the time. I had trouble finding the link.
This is the brand I tried .
Dom
2008 Element EX AWD TRP
First rule of troubleshooting is to identify ALL the symptoms before making a diagnosis or starting treatment.
Rarely will a problem have only one symptom, and only a hack mechanic, or a doctor, will try to cure a problem by treating symptoms.
Recently I've been having issues with mine going into gear and I'm fairly certain that it's being caused by a faulty brake switch. I say this because I have no brake lights, fuse is good(checked it with a meter) and if I press on the brake multiple times in succession and push/release on the switches plunger, I can get it to go into gear. I already have the switch which only cost me $5.58 and plan to install it fairly soon. I'll post results when I'm finished. :)
Just thought I'd post an update. I finally did get around to replacing my brake switch earlier today and just as I suspected, replacing it did fix my problem. To anyone who needs to replace theirs, let me just say it's an easy job and replacement only took me about ten minutes.
Hello all - I'm having the same problem, but I have the check engine light on. Further, when driving, my transmission will not switch gears as it should, so when driving say 40mph the engine is sometimes reving at 4k rpms.
I can sometimes get it to switch up by quickly shifting to neutral, then back to drive.
earliest appointment I can get with a mech is about two weeks from now.
Any ideas?
1 - 19 of 19 Posts
