The inside of my Element was a bit dark, but now I've increased the front lighting with this easy afternoon job. The map lights (or spot lights) now turn on when opening the doors, and if you've done the double dome jumper mod it works with the hatch opening too!
Video demo:
Tools: Soldering iron, stripper/crimpers, 8mm socket, pry tool
Materials: ~2.5 feet of 18 awg wire, T-tap & spade or similar, solder, 2x diodes, ~2A (not LEDs, straight diodes), heat shrink
Step 1: Remove the front dome light and spot lights/cubby. I won't go over it much, there are a ton of videos on how to do this. You pop the lenses off and remove the 8 mm bolts. The dome light drops down, the cubby and map lights drop down and slide back. Unplug the spot lights.
Step 2: Solder the diodes onto the spot light fixture. Attach the side of the diode away from the grey band to the front contact of the map light bulb holder. The front of the map light fixture is the side that faces away from the electrical plug you had to undo to take the cubby out of the ceiling.
Step 3: Heat shrink the body and exposed legs of the diode. You don't want them shorting off on the other exposed bits of metal in the fixture or ceiling. Twist the ends of the diodes together.
Step 4: Solder on your wire. Heat shrink again. Rout the diodes through the channels available so they don't get pinched when you re-install it. You can attach the tap now or after fishing the wire through the headliner.
Step 5: Fish that wire through the headliner. As you push the wire through the hole that the spotlight wiring pokes out of, push down on the headliner from the dome light hole and feel around for the wire, then pull it through. Tap/splice the wire that you have been working with into the green/red wire of the front dome light.
EDIT: for dome light switch control of the map lights (i.e. turning the dome light off will keep the map lights off when the doors are open as well) attach the wire to the switch side of the light bulb feed on the dome light. See my comment below
Step 6: Test! Plug in both lights. Spotlight functionality (click the lights on at any time) only works if the left side 8mm bolt is through the housing and into the ceiling. Dome light (door open) functionality will now pull a ground from the dome light and illuminate the spotlight/dome light regardless of that previously mentioned 8mm bolt
Step 7: reassemble. Basically unplug the map light housing, slide it sideways through the cubby, plug it back in, and mount it back in the ceiling with the 8mm bolts. Clip the lenses back on.
Hope this helped the poor elements like me that didn't have dome light functions on this map lights from the factory! According to the manuals I've read, all Es before 09 didn't have that option, so now you do!
Video demo:
Video demo:
Video demo:
