1 - 19 of 19 Posts
After a ton of research and thought, i think I finally decided on wheels and tires that I like and can afford.
I have a few questions and would apperciate any input from those who have experiece with these wheels.
I currently have stock 215/70 R16
Here is what im trying to achive:
-Cool look/Street/tuner look but not gangster looking ;)
-improve handling a bit. (i will not need it for off-roading ever.) I will use it in the city with snow in the winter.
-I decided to go with 18s and not 20s because i heard that 20s are too rough. Are the 18s a good balance of proformance, looks, and comfort?
first, here is my ride:
here are the rims
18" ASA AR2 V2 Machined w/Anthracite Accent
here are the tires
Pirelli PZero Nero All Season (Ultra High Performance All-Season)
Package Total: $1,188.00
go for it. i have similar but with more lip
they look nice. I would watch your gas mileage. I think it will go down a little. I had 17" TSX wheels with 225/45/17 tires and my mileage went down a bit, while my rpm's went up.. The sidewall being less than stock made it do that. Im not trying to discourage you or anything like that, Im just letting you know from my experience..
I like them, a lot. Those are a very sporty designed wheel. The tire diameter will be a little small, if you feeway a lot, you will notice mpg's go down, 235/55/18 would be perfection and look better as it fills the fenderwells up more. I say buy them, get them on, and post pics!! Next: Slam It!!!
Oh yeah, you will see driving and handling change, not a ton, but noticible, you will be a ble to take those curvy on ramps faster to merge easier, thats my favorite, its the only time to really have fun and have "rapid acceleration" and not get pulled over for it.
Discussion Starter · #10 ·
thanks so much for the info! very helpful!
so you are saying i will get better gas milage wth 235/55/18 ?
I do like low profile tires more. :D
Gas mileage will suffer because running a smaller diameter the tire has to turn more revolutions per mile. Example: 235/50 rotates 763.3 time per mile/diameter of 27.25"/speed at 62 would be 60 and the 235/55 would be 738.3 times per mile/diameter or 28.17"/speed would be correct. You would be reving higher to go the same speed therfore wasting gas.
Hope that helps
Hope that helps
let me add, that after installing smaller diameter tires, if you use the OEM speedometer to determine your speed, then your engine won't rev any higher. however, you won't actually be going as fast as the speedometer indicates.
if you base your speed on the cars around you and pace w/ them, you'll find that your speedometer will think that everyone is driving faster and your engine will be reving higher to keep up.
that looks really good. But to me, it doesnt look like they are filling the wheel well. Are they in from the body of the E?
1 - 19 of 19 Posts
