1 - 7 of 7 Posts
Tire Rack.com....I got some Firestone Winterforce's for $65, I'm sure you don't need winter tires but they work and they're cheap but I'm sure they have other cheap tires aswell.
Ask an independent tire dealer if they have some slightly used tires in the correct size. For example, someone may have bought new tires with only a few thousand miles on the originals, not because the originals were worn, but because they wanted a different look, style, or size.
Thanks Paul, long time since we talked on here! I called a used shop and they have a set but could not tell me the model of tires. They say they only stock 50%+ treadlife tires but set of 4 mounted is $199.00 which is the route I think I will need to take.
Being poor is no where near as fun as Al Bundy makes it out to seem. ;)
i just found out about this place, and its in winchester. Google "used tires in winchester" and theres a place, I think its called Ron's Used tires. You can get a set of tires (not matching, or only 2 match) for around $120.
1 - 7 of 7 Posts
