Try to PM Nismogriff about this. He's a good source for this type of question.
Man.....I haven't heard 'em called "phono" connections in YEARS!! ;-)With the 1721 you need to make the phono connections.
So what would be the best options for hooking this thing up to the factory system? I understand the sub-woofer portion but whether to use just the 70-1725 by itself or buy the AOEM-HON20. The AOEM-HON20 still seem confusing as to how the hu gets it power and what the rcas on that unit plugs into( HU im guess) i read the pdf for it and still cant tell if i will need just that or an additional harness. Im sorry if im turning this thread into a mess.
oh also is the Metra 40-hd10 the correct antenna adapter cause i notice it say 05 and up and i have an 03ex.
I used the factory brackets and slotted a couple of the holes ever so slightly to change the angle, then I used a double din trim ring from a Metra kit for a Odyssey. I can't honestly remember why I decided to do this, but I know that I ordered the parts specifically to do it that way.i figured it out. The 03-04 doesn't need the adapter since it doesn't have the XM option which required the adapter. Can you guys chime in on what dash kit is the best to install my f700bt Scosche, Metra or American International?
