1 - 10 of 10 Posts
This all happened today:
After driving around for hours today, I came out of a store to find my Element was strangely dead and had to be jumped.
Then, while driving down the road, I noticed the malfunction indicator lamp was on...then my radio started turning on and off by itself...then the airbag and seat belt indicators randomly turned on and off....then a grinding from under the passenger seat that sounded like anti-lock brakes....more instrument panel haywire...and then the car stalls.
It stalled four times on the way home...each time requiring a jump to get started again.
Any ideas?
would a bad battery explain the stalling?
It could! But, and this is a big But, it sounds like a bad connection. I would look at the Ground connection first, if the battery connections look good.
Dom
Moderatorium
Bad battery, failing in an open cell (internally disconnected), or more than one cell internally shorted resulting in a sustained voltage below about 8 volts.
Jumping will allow the engine to start and spin-up the alternator enough to sustain operation. However when it idles, without a working battery the voltage goes too low for many if not most of the computer-controlled functions. With voltage "squirrelly" around the shut-off threshold, you're going to see all sorts of strange behaviors.
Replace the battery and all should be OK with the world.
Based on my experience with batteries I have to agree with the others who suggested that you replace the battery. Please let us know if this solves your problem.
Discussion Starter · #10 ·
Problem solved
Just as all of you recommended, I changed the battery and it it working fine. Thank you everyone who provided help.
1 - 10 of 10 Posts
