Does anyone else have two interior bike attachments installed? I just installed mine, and now the cargo floor cover doesn't sit correctly in the back. It looks like the attachment closer to the front may be sitting on the spare tire, pushing that side of the cover up. Has anyone else experienced this?
In lieu of using the Honda mounts, others might consider buying bike mounts from Nasbar.com or performancebike.com for $20.00 each and mounting them to a board cut to wedge snugly between the side walls in the back. This way there's no permanent mounts in the way. It may not be quite as secure as permanent, but it's a whole lot cheaper. I suspect too, you could screw these mounts to the wheel cover with a little effort.
Nashbar part number DE-PBH
Performance part number 00-1616E
I mounted a fork mount to a 2X4 that is not secured anywhere and all is well. I spenet 30 bucks for 2 fork mounts and the 2X4, I travel often to races and have yet to have a problem, either Mountain or road bike or both.
