Has anyone installed an interior led light kit? If so, did you buy the components separately and make your own kit or buy a whole kit which came with everything?
I was trying to figure it out on Super Bright LEDs web site but ...
I saw this on ebay:
http://cgi.ebay.com/ebaymotors/4-KI...r_Truck_Parts_Accessories?hash=item4148952555
The seller has different kits and colors. I like that it comes with everything, can wire it all together and have one switch to turn them all on.
· Premium Member
It might not be a bad deal after I went through all that I have with LED interior installing. I know I spent more than $53.
Only thing to keep in mind I would add is that with individual or strip LED installation, you can add or subtract lights to give you the intensity level in certain areas, AND you can adjust where the light is thrown with more numerous, lower output bulbs.
Does that help?
I too have more lighting ideas, but it has been too cold, and I have been backcountry skiing every chance I get..... no time to tinker with the E.:-D
Personally I wouldn't buy from a seller who can't even post pictures of their actual product and a more descriptive detail about the l.e.d.s that come with their kit.:? As for that kit,without that info. it's kinda hard to say if it's a good deal,or not.
Ditto on what he said...you can get led strips on ebay for pretty good prices....
Browsed 12v LED in the search and found these in two secs:
http://cgi.ebay.com/ebaymotors/LED-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
48cm = about 1 1/2 feet.... that;s alot more light than 4 inch led pods (x4)
superbight is a good place. Also Oznium.com as well. You might want to look into a multi color kit so that you can change them. I run an flow lighting inferno UB V1 kit with 4 1ft tubes on the interior that all plug in to one controller. Yes it is more money but you will get the quality from it also. I have been through a lot of cheap glow and they wear,malfun, or just plain break over time. I have owned this same kit for 4 years now and is being isntalled on the 3rd vehicle with no problems.
Just depends on your budget and tastes.
