Got some EL rope lighting from Amazon. Ran it around the headliner and down the A pillars. Tied into the dome light for power. I always keep the dome light off because its too bright, and this adds the right amount of entrance lighting. Rope light has a “tuckable” fin i just wedged between the weather stripping or molding. No glue or tape, all fin, and stays in place.
Door opens or when you unlock from the fob, light comes on and will gradually dim off after ~20 seconds or when you start the car.
👍 or 👎 ?
http://instagr.am/p/CWU4xVXrvod/
Automotive lighting Vehicle Gas Automotive exterior Motor vehicle
Automotive lighting Mode of transport Automotive mirror Electricity Vehicle door
2004 Honda Element EX 2WD / 1993 Chevrolet S10 Blazer
That's badass. I had some remote controlled LED light strips in my Element before but nothing this cool. I second that we need more pics!
Discussion Starter · #9 ·
Yeah that’s clean! Do el lights come in red?
USB El Wire Red,32.8FT/10M Neon Rope Strip Lights 5V with Fuse Protection for Automotive Car Interior Decoration with 6mm Sewing Edge. https://www.amazon.com/dp/B0953LNFH4/ref=cm_sw_r_cp_api_glt_fabc_RANKGRNHJ9NVA0G4MS6D
Depending how you wire it in- there are 5v and 12v versions. If you cant find the 12v youcan always find a 12v to 5v converter-
Weewooday DC Converter Voltage 12V to 5V 3A 15W DC Buck Converter Module, DC to DC Reduced Voltage Regulator Converter Car Power Converter Adapter with Dual USB Output Power Adapter https://www.amazon.com/dp/B08R64L68D/ref=cm_sw_r_cp_api_glt_fabc_FRCB1NV5VTX88CEGPMXR
Or
12v to 5v Volt Converter, DROK DC Voltage Regulator Board Power Supply Module, DC 6.3-22V 12 Volt to 5 Volt 3A 15W Waterproof Car Volt Step Down Buck Converter https://www.amazon.com/dp/B07P663XJ...abc_FZN958CQNQ9X0CD97JZN?_encoding=UTF8&psc=1
