Started my E yesterday and after a few minutes noticed that air from vents was still warm even though the a/c switch was on (illuminated). Turned all the HVAC knobs and pressed all the switches hoping to reset something, but nothing helped: warm air for the entire 30 minute drive home. Also noticed that the compressor was not kicking in. When I got home, I shut off the engine, then turned it on again. The a/c compressor kicked in immediately and the a/c began blowing cold air. Happened again this morning. After initial startup no cold air, but after turning engine off then back on, cold air. Not sure if the following might be related, but this a/c problem comes on the heels of 1) a blower motor that began sticking and requires a kick (literally) to start moving again (dying bushing/bearing, I think), and 2) a check engine light that came on, but immediately went off when the guy at Auto Zone hooked up the diagnostic computer. These two problems occurred within the past week.
Any ideas? I searched the forum but didn't find anything resembling my problem. 2008 LX, 2WD, 70,000 miles. Thanks in advance for your help.
