1 - 17 of 17 Posts
Welcome to the EOC Xanless47! :)
Polished aluminum wheels need a lot of maintenance to keep them looking new. Brake dust, high humidity, and high heat attacks that shiny polished finish very quickly. Count on doing a whole lot of polishing if you want to keep those polished wheels polished! :)
Unless you are putting them on a show car that is stored inside 95% of the time (not what the typical Element owner does!), look for some wheels that are plated or powder coated instead.
Just purchased these wheels in flat black 16x9... waiting on my tires to come in before I can mount them on my Element. They have a -12 offset, not sure if that helps out.
I believe OEM size/offset is 16x6.5 5x115mm bolt pattern +45 offset.
Sent from my iPhone using Tapatalk Pro
2007 LX MT/FWD
Hello,
From some reading on this site. I was lead to believe(if, I read correctly) that the wheels on the Honda Element, offset was 42-? and an offset of 38-45 will fit without any problems ?(with stock215/70/16 tires). But, I'm only going by what I've read on this site... Wheels the fit....
Yet, the steel rims on my 2007 LX are stamped J 16x61/2JJ DOT TOPY K 10 09 06OFF45 which, would lead me to believe they were made Oct. 09 of 2006 with offset of 45. Your rims may vary....The Element I own was made in 11/06 according to the vin. label in the door jam.
Which, leads me to believe that a wheel with only 18 offset and AT tires will lead to problems in fitment.... Yet, it's not my car. Good luck.
Can I assume the lift kit was essential to make this tire and wheel combo work?
That I’m not 100% on… I think I saw somewhere someone was running 245/75/16’s on stock suspension but there was a number of issues of rubbing… I got the idea from another guy who had a 2 inch lift on his E with the same tire/wheel combo and had no issues so I assumed I wouldn’t have any issues with a 3 inch lift
I’m lifted 3 inches and I’m not even on 245/76/16 I heard the biggest without out a lift was 225/75
No lift needed with these tires barley rub under the fender till the plastic wears out I did it before my lift and it was fine
1 - 17 of 17 Posts
