I recently installed a 12-volt splitter/charger in my 2008 Element - plugs into the cigarette lighter and gives me three 12-volt and two USB outlets.
It also has a voltage display, and the way it behaves has me puzzled.
Upon starting, the display reads between 13.9 and 14.3 volts. After driving for ten minutes or so, this will drop suddenly to somewhere between 12.5 to 12.7 volts. It will then occasionally jump back to 13.9-14.3 and then back again to 12.5-12.7.
If I turn on the headlights, it will immediately jump to 14+volts and stay there for a while. Then back to 12.5+
The battery is not new, but it doesn't seem to exhibit any problems. The engine turns over rapidly and starts immediately.
I was always under the impression that an alternator-based charging system might register 14+volts or so upon starting, and the voltage would then drop gradually over a short time to a base level. However, I have checked with Dr. Google, who seems to think there are many different ways that the charging process may vary.
When dinosaurs roamed the earth and I was a young man, we had dynamos rather than alternators. Alternators are mysterious to me ....
Is this charging pattern normal? Or may it be that my splitter/charger isn't accurately reading voltage?
Any help is much appreciated.
Regards,
EJB
Regards,
EJB
