Pulled my coil packs and the one from the left most cylinder had a good bit of oil on it. The other three looked very clean.
I looked into the 'hole' where the coil packs go and could see a slight bit of oil sitting on top of the rubber grommet/gasket that, I think, seals the inside of the valve cover from the inside of the coil pack tube.
Is this likely an incorrectly installed tube seal or maybe a bigger issue?
The engine has not been losing oil between changes but there are some minor signs of oil spray on the engine block, none near this tube.
I'm working on changing the valve cover out for a fancy powder coated one, that's what started this work.
TIA
TIA
