If you are sticking with the stock wheels I would recommend looking at two sizes. The 235/70R16 may be a good choice. These are about 1" taller than the stock tires and about .75" wider. With your lift these should bolt up without any issues. If you want to push the limits you may be able to run a 225/75R16. This size is about 1.6" taller and about 1.2" wider. This size may require a little fender liner modification to clear in the front when turning.
Let us know if we can help you with a set of tires. We would love to earn your business.
Since you are not changing the strut towers, the lift does not give you more clearance for tires. 235/70/16 or 225/75/16 are the largest practical tires, lift or not.
Running a spacer may actually make it harder to run a larger tire. Think of your wheel wells as bowl shaped. You want to keep the wheel and tire in the deepest part of the bowl.
The spacer would give more clearance relative to the top of the strut tower, but make it more likely that the tire will hit the back of the front fender liner when the steering is turned.
There have been lots of threads that talk about fitting tires, and where they might rub.
I understand the desire for large tires. It looks great and gives additional ground clearance. Unfortunately, the E can only handle so much, and a 3" lift is not that big.
well lift is on...and looks great...will post some pics soon.....but i need to know... is it a positive for sure that 225/75r16 will fit w/o rubbing? because i am ordering tires tomorrow
not sure exactly yet...but going with either BFG's.... General Grabber or Yokohama...cant remember the Model but all these are aggressive tread tires...not all out mudders but something with some nice tread...but size will be 225/75r16 as long as it will clear...but i dont mind beating in the wheel well a bit to make it fit.
