I just purchased a Eclipse EA3422 4 x 50 watt amp brand new off Ebay and I realized something after the fact, my head unit has 8 volt preouts and according to the specs of this amp, it has an (input sensitivity preout)of .2-5 volts and also (input sensitivity amp out) of .4-10 volts. Which set of numbers should I be concerned with for the outputs on my deck. if it is the .2-5 volts will i have a problem with distortion or something with the 8 v outputs on my Eclipse HU.
Also for anyone looking for a decent small amp that puts out 50 watts x 4 at 4 ohms with .004 thd. It is a small 10.82 x 10.82 x 1.97 h and should fit under the seat pretty well. I will put up some pics when I get it installed that is if I get it installed depending on the result of what happens, question above.
