1 - 14 of 14 Posts
Is it just mine or is it common for air to continue to flow through the vents when everything is turned off? I can have all the climate controls off completely and it still blows hot/cold air depending on the temperature setting on the dial. Any thoughts? Its not on "high" or anything but blowing.
Thanks -mike
Although I don't know for sure, as I don't work for Honda, but I think it's typical. Mine does it too. Also, my wife's Volkswagen that the E replaced used to do it. I think all cars do it to a certain extent.
Moderator
It explains that in the owners manual.
But, if you want it to stop doing that simply push the recirc button with the fan set to off and no air will come through the vent.
Hope that helps.
Discussion Starter #6
Great stuff, I am glad I'm not the only one. Sometimes its just annoying but I'll try the recirculate button :)
It is simply the recirculation button....
If that is not glowing orange, then the vents are open and the faster you go, the more air will come in.
Yep, it's been that way on every car I've owned for the last twenty years.
Hope that helps.
Yep, that's what I have been doin'.... before I cracked'er up... :-(
Fumes coming in the cabin
Just experienced this lately since I have used my E more often that fresh air gets in the vehicle even with my HVAC control is in Max setting with the recirculation button on. So I did an additional test by turning off the fan and I can feel air flowing through the vents. Any of you guys experience this? I just hate it when there is a vehicle in front of me at normal distance. Makes me sick when I inhale the fumes.
I just posted this problem with my E today. I don't have a problem with my honda accord and toyota sienna. This should not be a problem first of all. The manual clearly says that fresh airshould not come in and it does even with the recirculation air button is turned on. It makes me sick when I follow other vehicles because the fumes get inside the vehicle and I believe this is a problem.
This is not normal.
This is not normal.
Have a shop check it...
1 - 14 of 14 Posts
