21 - 30 of 30 Posts
Discussion Starter #21
Second step is to drill out the two "shear bolts" ("bolt, break head," p/n 35102-SV4-003, No. 3 in illustration—see image here) so you can remove the top bracket ("holder, column," 35108-S30-003, No. 5) and free the entire unit from the steering column.
This will leave you with, in addition to the malfunctioning ignition lock you now have, an unlockable steering column. I hope all this is really better for you than having the thing properly repaired.
I'm currently trying to chisel those bolts off, without removing steering column which seems far too daunting. At this point it is my only choice as the full repair and tow is over $1100 and I won't have that much extra to spend for at least a month. (My ex-wife ruined my credit ages ago...) I actually ordered $400 worth of struts for the car the morning this happened. And continuing to rent a car for the rest of said month will just put me further behind.
Anyway, if everyone thinks you have a lockable steering column it probably prevents theft almost as well as actually having one.
Discussion Starter #22
Hey,
Thanks to everyone for your help. I only needed to remove one bolt to free the steering column. Car starts easy as pie now and drives fine. Just need to have the key through the black plastic end of ignition when starting. The rest of the ignition is now completely removed.
Thanks again,
Sam
I'd love to be standing by when this person gets pulled over for something and the officer sees that ignition system. Forget that. The vehicle is simply parked somewhere and an officer notices the ignition system.
Discussion Starter #24
Yeah, the steering column will look the same as I'm putting the cover back on, there just wont be any metal behind the key hole. And the registration is in my name so it shouldn't be a problem. I'm almost positive that in New Mexico there is no law saying you have to have a lock to put your ignition key in.
Yeah, I wouldn't worry about it. I'm glad you found a solution.
Honda Ignition Problems
I am an automotive locksmith technician based in Seattle, Washington. The notion that you can start a Honda with a screwdriver is completely wrong. Since 1998 most Hondas are equipped with an Immobilizer system. This means if it does not recognize a programmed key it will not start the vehicle. If you encounter an issue with your Honda ignition or door locks the best course of action is to contact a locally owned automotive locksmith. We agree that it is significantly cheaper and faster for a qualified locally owned mobile locksmith technician to help you in comparison to a dealership.
Please follow these tips when contacting a locksmith:
1. Make sure you are speaking with a knowledgeable locksmith technician and not a nation-wide dispatch.
Ask the technician the following questions.
2. Are you able to cut a laser cut key on-site?
3. Are you familiar with Honda high security locks?
4. Do you have the required Honda repair kit?
5. Explain your exact issue and ask if he/she can solve it.
EOC Rank: Crankypants
Welcome, SeattleLocksmithNinja.
If you read the thread carefully you will see that the OP is still using his factory key, so the immobilizer system is working as designed. The problem was a purely mechanical one, and he has addressed it, though perhaps not in the manner everyone would recommend.
Just yesterday I had this problem. I had gone to the hardware store and after a week of using a sticky key it just failed. The key would go in after a lot of fiddling but it would not turn. Since I was at a hardware store I tried a can of compressed air then some lock ease liquid and of course no go. Then I called my insurance and said "what should I do?" They sent me a locksmith who said he would rebuild the lock right on the spot and I said "do it".
So the damage was $530 with tax and now he says I have a new lock. For me this was way better then screwing around with all the other methods tried.
Actually if I may correct some things said in this thread after just having changed the ignition in my E.
1.) I bought my Ignition Lock from NAPA. And after about 1 hour from delivery I noticed it was just the ignition metal part without the immobilizer. I called NAPA and they said its sold seperately and you can reuse the old immobilizer anyways. You just need a scanner.
2.) You can use the old immobilizer. You HAVE TO BE VERY CAREFUL TO NOT UNPLUG the immobilizer. It clears the memory....atleast it did for me when I unplugged it.
3.) I was able to program my old keys and new keys into the new ignition. Before someone jumps at me for the above sentence, I kept the old ignition installed and I kept the big brown 6 wire ignition cable barely in the lock making me able to switch the cable back and forth to the old and new ignition lock. I kept the immobilizer unscrewed so it would be able to move back and forth as well.
4.) Honda Dealership arent the only people that can program. If you have your hands on a Snapon Scanner it will do the programming. I borrowed one from our competitor shop that brings us business and they happened to have one.
Sorry for the necro post but I found little very specific info on this problem so I thought that I would share my story (which is not done might I add but may be helpful/hopeful to some listeners).
One day I told my room mate they could borrow my car so that they can go get another battery for their insanely old honda hatch something. I rode my honda ruckus to work. (our household having alot of honda is just coincidence lol)
I got a text from her stating "how do you start yr car?"
huh
we talked over the phone and it seems like the steering column was locked and the key was not budging. This has happened before and I told her how to manuveur the wheel to "unlock" the ignition. No go. HUH.... well... I had to scoot from the coffee shop I was at to begin my shift at the cafe I work at. ha.
Later that night after playing a little nintendo switch to unwind for work, I go downstairs to move my car because the next day is street cleaning day.
Oops! I forgot the steering was locked!
NO matter I'll just mmmmmmEH! nope .... no go at all. moved the steering in the direction it would go for that small bit and the key just would not budge.
tried some of the tricks I read online: keyed the car into neutrel to move it back and forth. put back in park. try again nope.... Raised the car.... nope.
Street cleaning is tommorow!!!!! [email protected]$#!#$^@%@#$&$#
So from my own intuition (later to be confirmed by a mechanic friend) the ignition switch has mechanically failed.
This part (frustratingly) is a relatively easy part to replace if you don't mind carrying two sets of keys. EXCEPT this is Honda with the double edged sword of the immobilization chip or wevs (feel free to correct me in any terminology, its hella chill). Yr car needs to "talk" to yr OG chip that is in yr OG key.
So I put a note on my car pleading to please not give me a ticket.
That worked! :)
So I get my mechanic friend to come by to do what would take me 5 hours in 15 minutes.
I prepped it all by removing the steering column top and bottom covers etc....
So he chiseled away the break away steering column bolts as you may have seen on that famous internet website entitled "utoob" .... undid the ignition switch coil shindig from the plastic ignition starter switch and let it all hang out and Wallah!
Insert Key into ignition
use small flat head screw driver to toggle the ignition starter (careful now! it's plastic!) to START THE CAR and move the steering wheel.
what do I owe you for this house call?
"well now this buys you some time to move yr car for street cleaning till you can afford the time and money to order the part and drive it to My shop. I'll make it so yr original key works"
Great! Done deal!
Now. Is my 2004 Honda Element 4WD a DX LX or EX? woof
21 - 30 of 30 Posts
