1 - 1 of 1 Posts
I've been noticing a problem that is intermittent. Sometimes the keyless entry will work no problem and sometimes it will only work when Im next to my driver side door. This is a 2003 element with factory keyless.
I suspected the battery to be the problem, so replaced both of my keypads with fresh batteries. Still the same problem. The light on the keypads are transmitting when I press it, but no go unless im at the driver-side door. Any further like the passenger or trunk and no go.
Anyone have any ideas? Is there some sort of antenna that I can lengthen or where would I even check?
Thanks for your help.
1 - 1 of 1 Posts
