My element is a 2005 LX that did not come with keyless entry or key fobs. I have been interested in getting keyless entry since I bought my E 2 years ago, and after recently learning about door locks commonly failing I have been more motivated to get a keyless entry module to save the door locks from wearing down and eventually needing to be replaced.
So in doing some research it seems like you can get a keyless entry system with the module and fobs on amazon for $140, and after looking under my steering column it appears that I have the correct green port and mounting bracket to accept the module, basically plug and play so to speak.
However, I also have been playing around with the idea of having a remote starter. Mostly just for the novelty of it. It would come in handy sometimes I'm sure, but really what I'm wanting to know is:
1) is the keyless entry I've found the best option? I value reliability and understand you get what you pay for, but if there's a more affordable and reliable option out there I'd like hear any suggestions.
2) Will my selection of keyless entry affect the ability to get a remote starter?
3) Or is there an option to get keyless entry with the remote starter all in one "bundle?"
I know the two need to communicate with each other, but I'm no expert in electronics, so I don't know if it would make more sense to get these features in tandem, or if it doesn't really matter? Also, I can't seem to find a remote starter kit for elements specifically but I haven't done as much research into those. I wouldn't know how to make one myself so this might be a mute point and I'll just get the keyless entry on it's own and call it a day. Just want to be informed before making any decisions. Thanks for reading my first (lengthy) post on here, I'm happy to be a part of the element owners club! Any and all info or help is appreciated!
Since you're not an "electronics expert", I'd suggest that you go for the OEM keyless entry system which IS plug-n-play and forego the remote starting system which can get involved and complicated. For that, you'd need to locate and tap in to a lot of wires in various spots plus add a module to defeat the transponder in the ignition switch.
On the plus side - defeating that transponder allows you to use cheaper "practice keys" instead of paying $100 or more per key.
I just did a remote start install on a 2005 Honda Element EX AWD. I installed a Computer 1900-S with an ads-blade-tb for immobilizer bypass. There are 2 main harnesses right under the steering wheel where you get the majority of the wires that you have to splice into. For $5, the wirecolor.com photos and diagrams on the Honda Element harnesses were helpful in finding exactly what wires I needed to tap into. The single button remote for this remote start is nice. 1 click is lock, 2 clicks is unlock, and you hold the button for 3 seconds to remote start.
Compustar 1900-S:Amazon.com: Compustar CS1900-S All-in-One 2-Way Remote Start Bundle: Home Audio & Theater
ADS Blade TB: Amazon.com: OEM BLADETB Integration: Blade Transponder Bypass Cartridge-Model: ADS Blade-TB: trustusonline
I have a 2006 Element, also with no keyless entry or remote start. I have done a lot of research and from what I've read if you really don't know what you're doing, have it professionally installed. Groupon & Living Social runs deals frequently. I'm getting both installed next week with one 4-button key fob that will start & unlock for $300 (including bypass). I could have got it installed for less, $149 for just the remote start, but the location was not convenient. Whew, my post was long too. 😉
