1 - 8 of 8 Posts
The top right fitting in this picture is seeping out the top between the pipe/tube and the fitting ... I could only tighten it a hair ... anyone know if this is a flare fitting or an o-ring one ...Thanks Automotive fuel system Motor vehicle Vehicle Auto part Rim
Well it looks rusty you have to replace them with stainless steel ones
Problem is you cannot buy them ..have to buy the whole rack to get it ... I would like to know what type of fitting it is ... o-ring or Flare ... Kinda don't want to make it worse ... I can still drive it to the shop the way it is now ...But then I'd like to fix it myself ...retired mechanic from the 70's and 80's ....but ...some of this new stuff is "different" ...
Discussion Starter · #7 ·
Great find and indeed if your a mechanic from that time period you know how to flare brake lines so you could always make your own.
Your my Hero .... I ordered Both of the lines .. I did do Double Flares on made up brake lines "Back Then" This is much better ..factory lines .. I tried to find them and failed ...Thanks So Much ...Don
1 - 8 of 8 Posts
