2008 Element EX AWD TRP
If these are added to the existing turn signal lamps, load resistors aren't needed. This would be the case if you added signals to the side mirrors.
If these are led replacements for the original incandescent lamps, then you'd need load resistors.
Or instead of the resisters, just get the proper flasher module and be done with it.
where is the flasher located? cant seem to find it in the fuse boxes. thanks
