861 - 878 of 878 Posts
22x8.5 +32 Von Max VM4's on 235/30 front, 245/30 rear. Not entirely sure if I like them or not especially with the car at stock ride height. Only paid $200 for them with new tires so likely selling them to find some 20'' wheels.
I agree. I was planning on painting them black chrome or plasti dip them but just wanted to see how they rode before I invested anymore time and money into them. Here's a rendering of the car lowered and the wheels black chrome.
Those looks pretty damn nice to me! ;-) ~Chief
These are '05-'06 Nissan Altima SE-R 18"x8" forged aluminum wheels (made by Alcoa) with a +40 offset (OEM is +45) on used 225-60R18 Dunlop Grandtrek tires. This set-up surprisingly weighs exactly the same as the OEM set-up yet sits .4" wider and .7" taller than stock (215-70R16).
Now lowered with Tein Street Basis Z coilovers. Initially lowered with a 2 finger wheel gap all around but the rear fenders rubbed going over dips on the freeway, and steep driveways. Had to raise the rear 1/2" resulting in a 3 finger gap. In the future when my current tires need to be replaced, I'll downsize to 235/40 to drop it down to a 1 finger gap.
Just put some wheels from a 2020 Acura RDX on the tangerine dream.
235/55 R19s with a +50 offset.
Fronts bolted right up, but only clear the struts by about 1/8”. The fender liner by even less when turning.
The rears got a 5/16” spacer so the sidewall wouldn’t hit.
Not currently lowered, but considering a modest one (1-2”).
So far, no rubbing, and rides just fine. Barely any difference in feel for rocking a 29”+ wheel
Pretty conservative styling, but the price was definitely right. I may plastidip them some sparkly dark grey, but not sure yet...
201786
201787
I’ll also throw in some “inside shots” to show some of the clearances. Stock tire size first at the front strut:
201790
201791
And the new wheel at just over 29” diameter and a little over 0.6” closer to the center of the car (inside clearance similar to top clearance):
201792
201793
And the new rear tire just barely interfering, requiring a spacer (pic without a spacer):
201794
Hope that is helpful for people thinking about how a slightly bigger size might fit everything.
TSW VALE
20 x 8.5 40 offset
245/40/20 Nankang tires
no rubbing
lowering soon. BC coilovers with swift spring upgrade on order
202739
i've ran 16 inch wide rims, 17s, 18s, 19s, multiple sets of staggered 20 inch rim/tire setups. i'm lowered on stock cut rear Element springs and toxico shocks with Moog adjustable rear upper arms (i had coil-overs in the back, but the stock cut springs rode better), and in the front, i'm on CRX springs (because of an aftermarket strut replacement) and i've got about 2 inches of clearance at my lowest point (depends on wheel/tire height). before the strut replacement, before the factory strut issue, i had coil-over springs in the front, with no sleeves. it ran and rode nicely, at a perfect height.
i've had a pair of 20x11 staggered mustang FR500 wheels on the back of my Element, when people said those would never fit.
on the stickerbomb rims below...they are a 245/40/20 inch rim/tire combo. i ran a 3/4 inch mustang spacer in the back just by choice, no clearance issue when it wasn't used:
