Cheapy catalytic converter, installed by previous owner, died.
Pulled old cat and discovered that bracket holding bottom of exhaust manifold to block was broken and the head of one of the two bolts at the manifold was rounded-off by someone's previous repair attempt (because of obstructions, a socket and extension does not seat flat on that bolt head and I suspect a previous attempt to remove the bolt with an impact gun destroyed the bolt head).
Removed bracket.
I wire brushed the whole area and for three or four days sprayed the area with PB-Blaster several times each day.
Decided to cut a slot in the remaining head of the bolt.
Heated the manifold casting w/oxy-acetelyne and, using a straight bit from an impact driver with a 1/2" impact gun at 40psi, attempted to break the bolt free.
Ended up breaking the straight bit. BTW, used 40psi because I didn't want to break the bit, my goal was simply to repeatedly shock the fastener so that, ultimately, it would free up. I've been successful previously with many rotted fasteners using this method.
I've kind-of used up my standard bag of tricks. At this point I believe I have three options:
1) remove the manifold by separating it from the head and deal with the rotted bolt in a much more comfortable arrangement.
2) weld a nut on the remaining head of the bolt and continue to try and impact drive the bolt out.
3) accept defeat with only one attachment point supporting the bottom of the manifold.
I started option 1) and, with a 1/2"-drive, 18" breaker bar, attempted to loosen any of the five manifold-to-head nuts/bolts. At the point the breaker bar was bending a good 10-degrees without breaking free the fasteners, I decided the last thing I needed was to snap off one of these nuts/bolts. I abandoned option 1), although I am considering bying a cheap, Harbor Freight right-angle impact gun to free those fasteners.
I have prep'd for 2). Plan to lightly MIG-tack a 1/2" nut to the washer (to hold the nut in place). Then remove the C-clamp and weld the inside of the nut to the rounded head of the bolt. Then file away that external tack and try impacting the bolt out.
Option 3) is always a possibility.
Any suggestions?
Removed bracket.
Any suggestions?
