I have a similar issue: Low beams won't work (both sides happened on the same day -- definitely not the bulbs), but high beams do work (so do running lights). I think I'm going to dig into it more tomorrow, but if anyone has seen this before / dealt with it, I'd appreciate the advice (and I'd rather not spend the $147 at the dealership to get it diagnosed by h-nda).Low beams quit working for the second time on my '04 EX. Not the bulbs (replaced twice). Dealer replaced wiring harness 2 years ago. Any ideas?
Both of my headlights went out at the same time. I tried switching the bulbs, but no luck. I tried changing the switch and it worked. Now a month later the low beams are back out. They went out after switching from low to high and back to low beams. Any ideas?Just adding my solution to this thread which appears to be a common one for others: I just replaced the combination switch. It cost $40 at the auto parts store and they had it in stock. Took 15 minutes. Video link below of tutorial.
My new very best friend, exactly how a solution must be. Thanks!Just adding my solution to this thread which appears to be a common one for others: I just replaced the combination switch. It cost $40 at the auto parts store and they had it in stock. Took 15 minutes. Video link below of tutorial.
