1 - 7 of 7 Posts
I installed the Blitzsafe HON/AUX DMX V.1 last night in my LX. Rather than run a cable directly from the adapter to my phone/mp3 player/etc., I used this. I drilled the hole for the input using a Dremel and just eyeballed it.
The trickiest part was getting the rubber grommet around the cable and then seated in the hole properly, because seating it first, then trying to feed the cable through would not work. In fact, from the looks of the picture, I probably need to clean it up a bit more.
In the end, it works great and I'm very happy with the results.
Cool beans, ElDuderino. But what keeps the jack from sliding back when you press a plug into it?
I was a little concerned about that, but it's a really tight fit. The rubber grommet holds it in well. I'd have to really push hard to get it to budge. So far, so good!
Discussion Starter #5
1 - 7 of 7 Posts
