1 - 20 of 21 Posts
Hello everyone. I just picked up this 2006 Element EX FWD.
202075
I'll be keeping a log of work done, mods, and updates here.
Discussion Starter #2
First up, fixing the exhaust leak.
Simple doughnut replacement, here's a pic of the old vs new gasket.
202076
202077
This weekend I'll be spending a HUGE amount of time cleaning the interior and swapping the shot engine mounts.
I plan on pulling all major panels and giving them a good scrub by hand. They are pretty gross.
Today I pulled most of the interior. The front seats are basically the only major part left in the vehicle at this time.
Tomorrow I'll be scrubbing each and every disgusting panel by hand and drying them. I also need to vacuum out the chassis. I may pull the rubber floor as well, not decided yet on that.
202122
Discussion Starter #5
A continuation from before, every single panel was scrubbed. Here's some examples of how horrible it was when I got it.
202328
To get the items this clean I bought some drill brushes on Amazon and used Castrol Superclean
202331
I drilled out the melted plastic studs to pull the crap holders off the door panels. Here's the awesomeness inside.
202329
After meticulously cleaning all the blue parts they went into a box to await their blue to black conversion.
202330
The seats were a special level of hell to clean. I used Chemical Guys Fabric Clean, plus an hour and a half per seat with the drill brush followed by shop vaccing them. They were then allowed to dry for 24h with a fan on them.
"Oooh the armrests are blue?!"
202332
Discussion Starter #6
The next step for me was to change all the blue accents to black because, well, the blue looks kind of stupid here in 2019.
The rubber armrests and air bag were vinyl dyed with Duplicolor vinyl and fabric coating. They were hit with adhesion promoter first. I've found on Hondas, this holds up well over time. I've done airbags before.
202333
The plastic pieces were painted in just an average semi-flat paint, nothing special. After they were painted I wanted to enhance the silver accents in the car. I purchased 3m 1080 brushed titanium vinyl to wrap them.
202334
202335
202338
The center console was also painted black, then wrapped with the titanium vinyl. Gives it a newer model look.
202336
202337
I painted the kind of dark silver parts for the door panels as well as wrapped the speaker grills in grill cloth.
I used some gunmetal "chicago screws" to put the panels back on since I had to drill them out to separate the door plastics.
202339
Here's the speaker grills after getting some nice speaker cloth.
202340
While that was happening I cleaned the headliner with the Chemical Guys fabric clean using a drill and the drill brush.
The inside still had a funky smell even after all my cleaning efforts so I picked up an Ozone machine which worked wonders.
Headliner, not perfect but a WHOLE lot better than before let me tell ya.
202341
Discussion Starter #7
Here's how the airbag turned out. Missed the pic in the previous post.
202342
Next up was to put the panels back in. Here's some glamour shots. You can see the "chicago screws" holding the crap holders back onto the main door panel.
202343
202344
I had ordered some CoverKing seat neoprene seat covers because the seats all had rips. Installing here.
202345
202346
202347
And finally I fixed the engine mounts. I replaced them all but the rear one was the one in really horrible shape.
202348
Then I went to the junkyard to get a couple odds and ends and, well, I went a bit overboard. I found an element with a complete black interior missing a door panel. The rear seats were in 100% perfect condition. I'll find some better front seats for mine in time.
202349
Wow! I admire your ambition Meltman! I'm not so sure I'd want to get mine quite that far apart!
But, it certainly looks like it's coming together nicely for you!
Keep up the good work! : - )
Discussion Starter #9
Thanks! Certainly not my first Honda rodeo. I’ve had lots of tuner cars over the years. They all pretty much come apart and go back together the same way in Honda land.
I think next steps for me are to fix some of the lingering issues I’ve got.
  1. The heater blend door needs some love and lube to open and close freely.
  2. Battery needs upgrading. Have an AGM battery out of a 2019 RDX to drop in
  3. Figure out the SRS malfunction. Light reset resulted in it coming back on
  4. Figure out why the rear wiper doesn’t work
It’s a bit cold in Chicago so progress will be slower than otherwise.
I did get a leather pilot steering wheel installed though. It’s nice.
As to your battery, you also might want to consider upgrading to a 24F battery. (There are several threads on this site about it.) It's a simple upgrade, and will get you quite a few more CCA's for those really cold mornings! And because the 24F is still pretty common, the chances of you finding one on sale for a very good price are quite high!
Cold in Chicago? Imagine that! I've had enough of that for one lifetime!
I spent my first 17 years there. Then I spent my next 11 years in NW Indiana, which was actually much worse because of the lake effect snow! : - (
So on my 28th birthday we moved to SW Florida and have been here 33+ years now! Much better! : - )
Discussion Starter #11
The battery I got was group 48 AGM. Same size as 2019 RDX. It’s already installed. I’ll snap some pics at some point.
Discussion Starter #15
Appreciate it. I have a bunch of upgrades to be installed here soon. I just need some time and a bit warmer weather would help!
New radio. New door speakers. New tweeters.
Discussion Starter #17
Managed to get the radio installed. Sony XAV-AX5000 with the Scosche kit.
Here it is without the bezel installed. I was still trying to get steering controls working (which do now). On a Sony headunit you can use the Green/Red Stripe wire to 3.5mm tip and the Brown wire to 3.5mm sleeve for native wheel controls.
202565
With the Bezel installed. Had to shim a bit to get it flush but it is pretty close now. The color of the radio matches the OEM dark silver almost perfectly.
202566
Next project is to get these LED dome lights installed.
202567
Discussion Starter #18
Been working on upgrading the sound system. Since I am swapping all the gray interior for black I decided to modify the black door panels for the speakers and just swap them in when I'm ready.
All the doors will be getting 6.5" poly midbass drivers. The rear doors are gaining some tweeters as well.
202680
Speaker grilles on the rear drilled out for the new tweeters.
202681
I also rolled my own crossovers for these speakers. Crossing them at 4khz, plus an L-pad to normalize the sensitivity between the tweeters and the midbass.
202682
I also upgraded the front tweeters as well.
202683
202684
Installed the tweeters up front.
202685
202686
Discussion Starter #19
Small update on an issue I've had with my element. When I got it, the subwoofer trim and the subwoofer itself did not fit correctly. The tabs had been broken off of the subwoofer as well. Turns out, somehow, the previous owner managed to high center the vehicle and "dome up" the floor right in that area.
I used a large hammer to flatten the floor back down. It aint pretty but no metal is torn and everything fits properly now.
"The humpty dance is your chance to do the hump"
202861
202862
"Stop! Hammertime"
202863
202864
1 - 20 of 21 Posts
