1 - 13 of 13 Posts
Ever since I put Michelin LTX's in my E it has displayed a horrible wallowing on sweeping turns. It feels just like driving on a semi-flat tire! This sucks!
I have 36psi in all 4 tires and it's still unbearable.
I've tried to find a rear swaybar for it but I haven't had much luck. Is there such a thing?
Thanks
Muddypaws
Which model of LTX do you have? A/T. M/S or A/S?
I have had the M/S on my Element for the past two years (they are my "summer" tires) and find that they corner and grip well for an all-season tire. They are certainly not a performance tire, but the E is not a performance vehicle.
07 2wd 5-speedauto
I have Michelin Latitudes, more of a cross over than truck tire. Cornering is way better than the stock Wranglers.. 32 psi. Maybe one of the sway bar links has broken off?
I have the Michelin LTX M/S as well. I haven't encountered any issues cornering on them, however, I have experienced terrible hydroplaning with them during heavy downpour if traveling over 50-55 MPH on highways.
It's been really disappointing.
Check the air pressure maximum on the tire. The Michelin LTX MS has maximum air pressure of 35 PSI on the side. This is for the 215/70R16 LTX
I have had over 25k on my ltx's and run them 32 front and 34 rear and have no trouble. There is very little wear at this time.
Sorry to hear that you are having problems, but I run the LTX M/S's and have had no cornering problems. Could be shot struts?
The LTX is the best tire I have owned on any vehicle. They may be the AT as there is a bit more aggression in the pattern and I upped them one size to the 225s.
I noticed a hair more "float" if you seesaw the wheel but nothing major. Also, I thought just the opposite in heavy downpours. I am on the highway a lot for work and I comfortably travel around 75 with no issues.
The Wranglers were like water skis and I thought I was going to die on several occasions.
I too would look elsewhere in the suspension to locate your issue.
Good luck! (P.S. I have 80K on them and they show little wear.)
1 - 13 of 13 Posts
