1 - 20 of 53 Posts
Does anyone know how we can get more power from the stock engine...can we order a larger engine?... seems like a good idea. I get my new element in about 2 weeks, EX Red Standard.
Any Ideas???
tim
The TSX also has a 5 speed automatic and a 6 speed manual as it's transmissions as well, with a lot less weight to haul around (500 lbs. or so), plus it's lower to the ground.
As far as the hemi engine, the current hemi in the Dodge trucks is a 5.7L variety. The 426 hemi was well over 6 liters.
Honda will probably offer a SIX in the Element in the future. That's what the competition is doing. I think Nissan just upped the Engine on the X-terra....
A six makes the E much more functional (with a couple other changes).
Ya the Xterra has an optional s/c'd 6 cylinder. Nothing new though really. It's an absolute pig on gas and puts out something like 210hp I think? That's pretty lame considering.
I can't see Honda putting a six in the Element before they put one in the CRV. If they did they'd have a real problem selling CRV's I bet.
I felt the same way about the 2.4. On my initial oil change I went to synthetic and a K & N airfilter and a noticiable power increase. Until someone comes out with a cold air induction system it will do.
[quote:67fbb1e51d="sundance"]I felt the same way about the 2.4. On my initial oil change I went to synthetic and a K & N airfilter and a noticiable power increase. Until someone comes out with a cold air induction system it will do.[/quote:67fbb1e51d]
It might help the "butt dyno" but you won't see any real special increase on a dynamometer.
K &N? Can you elaborate on what this is?
K&N is a brand of air fiter.
It is a high performance air filter that will directly replace the factory air filter. It is also reusable. You just wash it and re-oil it and it is good to go. I think they have like a million mile warranty.
[quote:fec44f8caa="Ramy"]
It is a high performance air filter that will directly replace the factory air filter. It is also reusable. You just wash it and re-oil it and it is good to go. I think they have like a million mile warranty.[/quote:fec44f8caa]
My question is: Does the K&N filter out the dust and crap as well as the OEM filter? I have to assume that less restriction means a lesser quality of filtration, thus more stuff gets into the engine?
Absolutely not. The K&N allows more CLEAN air to pass through. I've used K&N or similar airboxes on every new vehicle I've owned. Stock air intakes are needlessly restrictive in order to reduce "noise". removing those restrictions lets the engine breathe more freely.
You would think so but I can speak from experience that K&N makes some very good filters I had one on my 96 and 98 civic hatch and it made a noticable difference. The special oils used to lubricated the filter attract a lot of the dust and the design of the filter itself while lending itself to allowing more air to enter the design catches more than your oem filter will. I strongly recommend the option it did great things for me in the past. The synthetic oil however Im not sure how this imcreases horsepower I doubt that stongly however it has given me a noticably better gas mileage.
K&N filters use a cotton a folded oiled cotton gauze material that filters and breathes better then the OEM version. They have been big in motorcycle filters for years, plenty of dust testing.
I installed mine with Mobil 1 synthetic and removed the extra "horn" (near the battery) on the stock air intake... get better throttle response and sounds better too. It appears a cold air intake like an Injen or K&N Typhoon is the way to an easy 10-12hp. CAI's have a "power bump" from 3000-4500 which is perfect for the E's low end torque and where the engine likes to run...
[quote:b3bec7b2c0="lizzurd"]You can always swap in the motor from the RSX type S....you would gain 40hp but lose 20 lbs of torque.[/quote:b3bec7b2c0]
Better yet...just buy a RSX-S as a second car..... :p
Nah, pony up for the S2000, another 40 HP on top of that ;)
[quote:60110ba133="HEK"]
Better yet...just buy a RSX-S as a second car..... :p[/quote:60110ba133]
1 - 20 of 53 Posts
