I have a problem with my Driver's door. When I open the door, the car doesn't recognize the door is open... no light and the car will re-lock cuz it doesn't register that the door is open...
I bought a new switch thingy, (the little button that is on the back door.) But it still doesn't work.
Any ideas what to do next?
Thanks in advance,
Tam
You might have a bad ground on the door switch. The screw that holds the switch in the door is also its ground; check for corrosion. Also check under-dash fuse #10 and under-hood fuses #3 and #9.
Does the passenger's door switch work correctly?
Thanks Dan, I will check those fuses when I get home next weekend (in NC and SC for work this week)
Yes the passenger's door works. I checked the ground, it looks good. The light turns on when I open the back door on the Driver's side, just not the Driver's door. Lights also come on when I unlock the doors with the keyless entry.
Do ya think the driver's door would have it's own fuse?
Tam
all the doors share the same fuse.
(power comes from battery thru fuse and wiring to light.)
each of the doors can provide a ground to complete the circuit.
so, if the driver's door doesn't have a ground it won't complete the circuit.
if you've already changed out the switch, then it has to be a problem w/ either the wiring that goes to the door switch, or the ground on the switch.
